Sound Off intersector wiring
paff2
842
Lancaster, PA
I have 2 Intersectors in single color. One has the inline flasher and the other has the built in one. Both have the the steady burn, and also show the slave option. Since I want to use an external flasher for them do I set to steady or slave? Also they appear to both have cruise mode as well. I debated using another flasher for the cruise so I could use more of my lights with it. If I dont go that way is the Cruise mode easy to control? (1 wire?)
Thanks
hitman38367
881
West Tennessee, USA
I don't think the in line flasher one plays well with external flashers, or at least that's what I've always read/been told. The one with the built in flasher can be set to slave mode and run on a flasher all day long though.
paff2
842
Lancaster, PA
Bother! That’s not what I wanted to hear.
paff2
842
Lancaster, PA
I hooked up an inline flasher to an external flasher and it worked fine. Your results may very
Did you put it in slave mode or just set to steady burn?
GSPS629
