SoundOff ETSA380R wiring
Chewy519
11
North Carolina
Hello Im doing my first install and im trying to figure the best way to wire my SoundOff ETSA380R. Wiring instructions showing Mutiple Hot wires. Do I need to run them all to the Hot battery post or can I run a main hot wire and use a fuse block.
MtnMan
1,533
Eastern PA
Yes, a fused main feed and distribution block will work. Also note that the fuse ratings recommended by SoundOff represent the maximum capacity of the unit. For an LED install, you won’t need that much current.
Chewy519
11
North Carolina
What size power wire should I run? I only got to run a wire from under passenger seat to under driver seat.
sadlad
