For Sale SoundOff mPower 4" Fascia (Red/Blue)
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
Brand New in the bag 4" 12 LED Screw Mount mPower Fascias in Red/Blue. Only have one available.
$70 plus shipping. Usually sells for $105
SoundOff's mPOWER Fascia series is the most extremely compact line of LED lights offering Single, Dual and Tri-color capability. Fascia’s next generation design and mounting options allows the light to be integrated nearly anywhere on the vehicle. The mPOWER Fascia series is the result of a collaboration with Dow Corning to develop ClearDuty optical design. ClearDuty molded one-piece housing and optic design delivers advantages over conventional polycarbonate lenses. These advantages include: A smaller footprint with maximized candela output, greater resistance to gravel pitting, scratching or cracking, improved sealing to prevent water from entering light, and higher UV and thermal stability to prevent lens from yellowing over time.
mPOWER Fascia series lights are Sync2 lights and are syncronizable with up to 24 Sync2 compatible lights such as nFORCE series and Dual Color Intersectors. Over-Voltage Protection: When an over-voltage condition is detected, the module will flash an over-voltage warning pattern of 50mS ON/950mS OFF to alert of the over-voltage condition and protect the electronics from damage due to heat/voltage. Thermal Compensation Protection: The LED module is designed to provide maximum power output while providing protection to the electronic components by reducing the output power at extreme temperatures. The mPOWER Fascia series is available in 3 mounting styles: Quick Mount, Stud Mount, and Screw Mount.
Features:
  • Single, Dual and Tri-color capability
  • Ability to integrate visually into today’s police vehicles
  • Collaboration with Dow Corning to develop ClearDuty optical design
  • ClearDuty molded one-piece housing and optic design delivers advantages over conventional polycarbonate lenses
    • A smaller footprint with maximized candela output
    • Greater resistance to gravel pitting, scratching or cracking
    • Improved sealing to prevent water from entering light
    • Higher UV and thermal stability to prevent lens from yellowing over time.
  • mPOWER Fascia series lights are Sync2 lights and are syncronizable with up to 24 Sync2 compatible lights such as nFORCE series and Dual Color Intersectors.
  • These lights have Over-Voltage Protection.
  • These lights have Thermal Compensation Protection.
Specifications:
  • INPUT VOLTAGE RANGE: 9-32 Vdc
  • CURRENT DRAW: < 1.0 Amps @ 12.8Vdc, < 0.5 Amps @ 25.6Vdc
  • OPERATING TEMPERATURE: -40° C to +65° C
  • CERTIFICATIONS: SAE J595 and J845 Class 1 certified and CA Title 13, Article 22 compliant
Available Mounting Styles (See the Dropdown): Quick Mount, Stud Mount, Screw Mount
Check out the wide variety of brackets and other mounting accessories in the side bar on the right.
DIMENSIONS
  • Quick Mount: 4.04”(10.3cm) L x 0.92” (2.3cm) H x 0.47” (1.2cm) D (from mounting surface)
  • Stud Mount: 4.04”(10.3cm) L x 0.92” (2.3cm) H x 0.42” (1cm) D (from mounting surface)
  • Screw Mount: 4.52”(11.4cm) L x 0.92” (2.3cm) H x 0.42” (1cm) D (from mounting surface)
woobatu
