Streamlight Lantern
JazzDad
5,165
USA
Does anyone have a wiring diagram for a Streamlight lantern? What is with the dual-filament bulb? (Three wires going to it, that may sense the resistance.) I want to replace it with a regular sealed beam I have.
Oct 20, 2010
809
Rehoboth, MA
Streamlight built models that had dual filament bulbs so that when one filament blew, the switch could be flipped and the other filament would light up. It was a failsafe.
JazzDad
5,165
USA
So their circuitry feeds one filament, then the other if the first one burns out? I put a DVM on each of the (I assume to be) positive leads (grey and black) going to the lamp. Both read 0V. I am assuming the green wire is negative.
I don't think there is a spot & flood pattern - there is only an on/off switch.
Oct 20, 2010
809
Rehoboth, MA
No, I thought the switch was dual throw but it's been so long since I researched it, I'll have to try and look for the info.
JazzDad
5,165
USA
Any help is appreciated.
Jesseclark2448
