HPD84
K9Vic said:The round plug is not for a controller, it connects into the MNSTAR wiring harness that goes to a set of relays controlled by their on custom toggle switches. You have to cut the plug and just wire it to what ever controller you want to use. The MNSTAR is one huge wiring harness that has everything on it for the lights, siren and radios so the install is quick and easy, basically just plug and play. It is very expensive and and one of the few items that they have always swapped between cars. The the MX7000, Freedom and Liberty are setup the same with the lighting so they can just swap the wire harness as they cost like $2000 new.
The square 12-PIN is just a Whelen LED arrow controller, the TLD1 you have will work fine.
360SafetyGear said:Question if you don't mind, the TA wires, which one's are for left/center/right? Been trying to figure it out on the engineering rendering but to no avail. Not planning on using the TLD1 but wiring into a Touchmaster Delta (latching switches)
Thanks in advance!
360SafetyGear said:It has the 12 pin square harness (number 32), I see it in the Whelen PDF but cannot figure out what each wire controls. I really don't want to have a separate controller LOL
360SafetyGear said:Which means it is dependent on a controller if I am understanding correctly?
Thanks for all the help fellas!
CenTexPSE said:Can the pattern be changed on the flashing tds?
MEVS06 said:IIRC no they can not.
