Touchmaster Delta and Whelen Alpha 12Q Wiring Questions
dasuriano
120
Colorado
Have the two sirens installed in my truck and neither are fully functional. I think they're simple fixes, but I just can't figure it out.
I can't get the sweep mode working on the TD. I have a separate switch wired for the horn ring and it isn't tripping the sweep function. I've tried to match the diagram the best I can, but it isn't working correctly. Does it need power or ground or something to function correctly? Or does it just jump between the two connection points on the back of the unit?
And I can get the 12Q to work on manual mode, but not with the wind down. I am fairly certain that the pins aren't the correct ones and they aren't long enough. As I was wire testing the connections, I made contact with the pin end and shifted it, turning on the siren. Does anyone know where I can find replacement pins for the connector?
And last question. I want to wire in the siren brake for the 12Q, but didn't see it in the manual. Which connection is that?
dasuriano
120
Colorado
I did manage to figure out the Alpha 12Q. I had to order new longer pins, but it works correctly now.
I still cannot get the TD to work correctly.
-The sweep does not work. I have tried wiring in a separate switch for Horn Ring, as well as triggering it off a function switch on the siren itself. Neither seem to work.
-The Manual button does not work either. It gets stuck in the depressed position and does not trigger any noise.
-And the Aux switch does not work in either momentary or latched mode.
Is there any hope for the unit?
OPD1222
8
OK
I apologize if I misunderstand your question, but I do know that the quick work around for the sweep function is to attach about a 12 or 14g wire from the horn ring terminal to the RLS terminal on the back of the unit as oppose to splicing into your vehicle wiring. Either horn ring terminal will do I believe. Then you just press rls to activate sweep.
OPD1222
8
OK
But then again with your man button problems, I'd say just get another unit from Ebay. That one sounds like a host of future problems.
New in state!
