Waterproof Electrical Connector Plug
fordtruck661
96
CT
Wanted to know what everyone is using for waterproof connector plugs. Right now I have some cheap ones off of ebay and my searches have not turned up much. They are going to be used on a back rack for a truck.
Evtech161
157
Woburn
You can always try a marine supply shop... but if you can do without the plug.. solder and Heat shrink is the way to fly.. I've seen those other water proof conectors fail, and they are really way over priced
buddek09
339
US, Ohio
Weather-pack connectors, which are what are pictured in dmathieu's post. Can get them as single pin all they way up to 6 pins and handle up to 12 gauge wire.
Reactions: firebuff17
buddek09
339
US, Ohio
Also not sure what you're using them for but the Weather-Pack connectors are rated for a max 20 amps. Amphenol ATP's are rated for 25 amps but only offered as a 2 or 4 pin connection.
bullfrog4ever
336
Indiana
I've used Delphi Weather Pack connectors and Deutsche connectors. Both work well.
If I don't use those, then I either solder and heat shrink or waterproof butt connectors that have adhesive heat shrink on them.
Caldwell205
