dpd4703
Just got around to replacing a PA300 in our mobile CP (old DFR 1997 Wheeled Coach Type I) with a Whelen 295HFSA1 that I purchased on ELB a good while back. When switched "on" the sci-test does not light up, but the PA and radio rebroadcast work fine. When the airhorn or siren tones are activated I get a slow but steady "popping" sound through the speaker and the spkeaker 1 light flashes as the popping sounds.
Any ideas where I went wrong installing or do I have a bad siren? I used the existing wiring from the PA300 install. I am unsure if the siren brake or aux enable wires were capped and will check that when I go back in tomorrow. Thanks for any help...
