Whelen 295SLSA6 Output ???
Andy L.
282
Michigan
Hopefully a quick answer to this one...
On a 295SLSA6, if I program an output to activate from another switch will it also turn off with that switch?
Example: I want to have a HLF on the first push button (output #6). If I program Slide Switch 3 to activate output #6 will output #6 turn off or remain activate when the SS is backed down to another position?
fcicars
125
Washington State
It will turn off with the slide switch. However, if you have the button activated prior to turning on the slide switch, I think it will stay on after the slider is backed down, but I'm not positive. It makes me curious though. I think I'll test it out Monday.
Hmood
