Whelen 9M412 and CS225 Power Source Questions
WhelenNDealin
575
Ontario, Canada
I recently got a mini Edge 9M. I was looking at the install guide and saw that it has two power sources. My first question is if the 9M412 has selectable patterns. There's no Scan-Lock wire. I found some older posts asking about this and the thread ended up with a non-answer.
My second question is about the CS225. Is this for powering additional front or rear strobe tubes? The bar has takedowns and I'm hoping to get a couple of strobes or flashers in the rear of the bar.
Any info would be very much appreciated!
Nolines
1,681
Margate, FL
Yes the cs225 is for powering 2 additional strobes wherever you decide to put them, I'm putting 2 on the rear so the bar works in a circular strobe pattern after changing the setup of the wiring as to what fires which strobe. I can't remember if it has 1 set strobe flash, 1 of the wires turns off the front strobes.
aidey1234
