Whelen Amber LED Upgrades! BRIGHTER / HEATED LENSES / HARDCOAT
dmathieu
May 20, 2010
8,783
S.W. New Hampshire, USA
Did Whelen recently upgrade their amber LEDs to a brighter diode?
I just saw some amber Micro edge, and some 400 LEDS on a DOT truck, and they blew me away (daytime).
They were much brighter than any of the whelen amber LEDs on the other trucks, and the brightest amber I've seen.
Amber has always been the dimmest LED color, but not any more.
Dan
Mobile Fleet
35
New York
They did switch to a brighter more orange or gold colored LED a few months ago. If you look at the power wire on the lighthead it will be orange instead of yellow now.
Solvarex
561
Canada
I call it peach. Wasn't a fan at first but the more I see it (on my vehicle) the less I dislike it. They're certainly bright.
got_yogurt
BC, Canada
I noticed one of the local highway maintenance trucks has a new Responder LP on it with LIN-6's and the new responder blows the old ones away... I couldn't figure out why until now.
dmathieu
May 20, 2010
8,783
Here's a possible answer as to why these Whelen heads look so bright.
Go to the 5th block down on the page.
http://www.pavementvideo.org/2011_EMTSP/PDF/5%20-%20EMTSP%20-%20Presentation-Whelen.pdf
The Phillips site notes that the PC amber LEDs deliver 4-5 x more light output than standard LEDs.
Also, look at the heated lenses, in blocks 6 and 7, to keep snow off!!!! Activates at 35 degrees and keeps temp greater than 32 degrees!
Also, hardcoated lenses!
bluestinger90
657
BC / California
Whelen switched from CREE diodes in 2010, to the much brighter Rebel diodes in 2011. I've compared both, and Rebel is much more intense. It's also a lighter shade of yellow, instead of the golden amber color the CREE had.
EVT
622
Midwest
Just amber or all colors?
kitn1mcc
2,571
Old lyme ct
yeah they did alot of work on the Lights the last truck i did i was like WOW i just put a set of L31 on Truck man are they insane. (pics in install later in the week)
dmathieu
May 20, 2010
8,783
New amber LEDs L31 in cruise light mode only, in high (brightest) setting
Day, and night.
There are 4 cruise light brightness settings. Only the 2 dimmer settings can be used to stay on when the beacon is flashing. The 2 brighter settings will shut off when the beacon is turned on.
joeparv
379
US. New Jersey
They prob switched to cree LEDs. Code 3 did. They used to use the rebels but they now use the cree. I had a rebel amber n changed it over to the cree ones. Alot deeper color than the rebels were
RetLt2020
