NavyShot242
Hello everyone.
I need some help with what everything does and getting things working/fixed. I purchased this Whelen Edge 9000 52" for $50. It came all red and someone has been inside this light before as lenses were mix matched.
Pictured is everything I beleave to be important of the lightbar, and what all is needed to find information. There are only the six strobes on the front and alley lights on the sides, nothing in the back. I tried to play with the wires and see what does what, but could only get three wires to work and light up the corner strobes and the ones on the outside on the front. Alley lights work, but are dim. The middle two strobes I couldn't get to work. They have wires coming from them, both containing three wires each, red/black/white, but arent in the main harness. The rest of the images show other plugs that I assume go to extra strobes if present, but don't know for sure.
The end goal is to have led alley lights and takedowns, strobes on all four corners, strobe peircer II in the center, and strobes in the front. The back I plan to leave blank as it will be blocked. Thanks for any help and information provided.
