Whelen Edge 9000 Wiring Diagram(s)
oldstrain
10
US - Ohio
Help!
I am restoring 2 Whelen Edge 9000 Lightbars with Whelen PCDS-9 in-car controllers. I need the following:
1. Wiring from lightbar to controller and controller to 12V.
2. Wiring from lightbar to 12V.
3. A recommendation for a 12V power source to power all the above in a static indoor environment.
In short, I need it all!
Help much appreciated in advance.
Paul Brown
foxtrot5
3,002
Charleston Area, SC, US
There are many variations of the Edge bars. Look for a sticker on the bottom of the bar, should give you a model and serial number. That can help a lot. Your other option is to simple "guess and check" find the biggest (thickest) red and black wires hook the red to +12v and the black to ground then start hooking each smaller wire up and see what turns on!
oldstrain
10
US - Ohio
oldstrain said:
Help!
Paul Brown
As usual, I forgot to post all info.........let's try again.
They are 9308-PCDS-9 bars, and PCDS-9 (configuration 230) controllers.
sory
RyanZ71
1,001
Denver, Colorado
Caldwell205
