Whelen Model 64 Series Halogen turn signal problem
kabsher8093
176
KY
Passenger side rear turn signal quit working the other day. figured it was the bulb. Bulb was blown so i replaced it. It still will not work as a turn signal, but it will flash when the hazard lights are engaged...
I figured it was a grounding issue do to it being on a fire truck (pumper). I tried a pulling the ground from the other rear turn signal, still nothing.
Checked fuses and relay, all good. I thought maybe it could be the turn signal stalk but the front one works..
Ant ideas?
Kevin.
kabsher8093
176
KY
There is a 6 pin plug under the stalk that had come lose enough to only make the one rear turn signal to not work.
KI_CopCar
