Whelen patriot question
deelony
185
LINY
I just acquired a LC whelen patriot recently. Finding the manual online I was trying to get the takedowns and alleys to flash and in place of the two wires is a left and right traffic adviser motion to the rear 4 inner light heads. The rear 4 inner layout isbstrobe/led/led/strobe. I've never seen synchronization between a strobe and led before so that was interesting. But now does anybody know how to flash the takedowns and alleys?
deelony
185
LINY
yeah thats what the manual says but when i trigger it it does a traffic pattern with the strobes and 5mm leds. so im stumped
Nathan R
Mar 27, 2014
853
USA
Here are the files I have compiled
  • Edge LFL LC Installation_1.pdf
  • Edge LFL LC Installation_2.pdf
  • LFL Patriot and Strobe Ultra Upgrade to LED.pdf
  • LFL Patriot Data Sheet.pdf
  • Edge LFL and Ultra Personality Module.pdf
  • LC LFL IO Board Replacement.pdf
emtanderson51
3,795
USA Massachusetts
White with dark blue tracer is the flashing TD/AL. If that does'nt work, open her up and locate the main board. There is a 3 pin plug next to the giant control harness plug. Check to see if there are 3 wires going to that plug. If not? You don't have flashing alley and TD.
deelony
185
LINY
Thanks Steve. are your familiar with he traffic advisor function between the strobes and leds in this bar? is it common or do i have a special program or something?
emtanderson51
3,795
USA Massachusetts
Check and see if you have a personality module> That is the only possible way I see your bar doing that...
Advancedstreet
