Whelen PCC8R
Benny8743
2
Echelon, NJ 08043
I just received my switch box and was wondering two things. First how do I set up one switch to turn all my lights on and the second after running the power wire for my lights to the switch box where do I run the ground wires to. Thanks
Nolines
1,681
Margate, FL
A chassis ground point! As long as your ground point is a decent connection point.
As for what switch to turn on all the lights, umm that doesn't appear to be a option based on what I just read.. you would need a slide switch without further wiring...
2004p71
367
canada
You could always use a relay on switch number 1 so you can run multiple light to a max of 30 amp.
Da-Sarge
393
Canada
I actually have the same switch box I use the switch one as a master to turn on all lights it triggers relays ive wired to take the load works very well you can run low current trigger wires directly all the ground wires ive ran to a bussbar connected to ground I hope this helps
covert
