Whelen PCCS9NP Help
Impala9C1
189
Arizona
The switch is broken. How do I open this. I do not see any screws or anything to remove. I don't want to break it.
the 4 screws on the outer corners that hold the front bezel on are what you remove to open it, as for the slide switch it has been messed with before and should not be riveted on and should also be 2 more screws you will have to carefully drill it out, as for a replacement I have some in stock
bfpd108
