Whelen Rotabeam 600 side warning
LED
613
New England, MA
Hi friends, anyone have experience with Whelen Rotabeam 600’s? I want to mount 2 on the side of a newly ordered dump body and want to know if they will provide enough warning to the back and front. I could always install beacons on L brackets but these would be more streamlined.
JohnMarcson
May 7, 2010
10,976
Northwest Ohio
I consider their side warning to be "secondary". You get about 50-75% output to the sides IMHO by eyballing it.
LED
613
New England, MA
Thank you for the reply John. I see that now. Sadly Whelen used to make aviation wingtip lights in 12v Amber for this exact purpose and they worked great.
JohnMarcson
May 7, 2010
10,976
Northwest Ohio
Whelen made a few different lights in LED and strobe for this purpose. The HELS even made it to LED before being replaced by the "head board" led.
  • headboard.pdf
Reactions: Dave F and LED
LED
613
New England, MA
John, you are an absolute myriad of information! The HELS was exactly what I remember from a few years ago!
JohnMarcson
May 7, 2010
10,976
Northwest Ohio
I actually impulse bought two NIB/NOS HELS strobes in blue (for far north Canadian Plows) because this thread made me nostalgic. I will post pics/video when I unbox and test them.
Reactions: StEaLtH2 and Dave F
StEaLtH2
2,159
New England
Out of curiosity what is the price point on the RotaBeams. I love the idea of this, but feel you would still need to have a pair of something on the tailboard additionally. Very bright lights, we have six on our Ladder. Keep us posted.
JohnMarcson
May 7, 2010
10,976
Northwest Ohio
pdk9
3,834
New York & Florida
+1 on what John said. If you went with some 180-degree light on the sides of the dump body, that would certainly cover your side warning, but I would still recommend forward & rear facing lights to serve as your primary front/rear warning
I love Whelen, but their rotabeams and V-series surface Mount lights are a overpriced IMO. In this case, I would recommend looking into SoundOff surface Mount intersectors for the sides (they provide approx 180 degree coverage) and I would have forward and rear facing surface Mount soundoff Mpower fascia 4” lightheads. The mpowers are super rugged b/c of their silicone construction (which I think makes them a winner for a dump truck), they’re low profile, and they can be ordered in dual color (amber flashing with steady-burn white for some area/work lighting). You could also scrap the 180-degree intersectors all together and just put some mpowers on the side of the dump too
JohnMarcson
May 7, 2010
10,976
Northwest Ohio
Good points and I agree with you.
The V series and rota-beams are a product I like, but the applications are limited and the price is high. Sound Off is always my second choice "or on a budget" choice. There are lots of options, but sticking to a basic "DOT" setup is probably more effective and cost friendly. There isn't anything I would recommended for 180 degree coverage that is worth the money for what you are doing IMHO. It's too bad Whelen has discontinued their "headboard" LEDs, those were a nice mounting option to get 180+ degrees from a surface mount/sealed light. They are trying to fill that market with the V versions of lightheads and the rota-beam 600, but it's not quite the same coverage. Out of all the V style lightheads I do like the M6 and M9 V versions the most as they give you a downward flood and a bigger 180 degree surface than the other options. But again the price is probably not worth it for the application.
The surface mount intersector from Sound Off is a good cost saving alternative like pdk9 said, but I also agree that the 180 degree portion of the build could be eliminated and covered by other means if cost is a factor. However if you plan to speak to the issue of 180 degree light with a beacon, the market is also not great. I don't think any of the 360 degree beacons really come close to Whelen's L31 and L32, but those models are priced at the cost of a mini bar. You could buy a LED responder or Century mini bar for each side for less than a pair of quality 360 degree beacons. If you plan to speak to the side/180 degree issue with more surface mount lightheads, the "hundred series" super LEDs from Whelen have dropped in price dramatically and there are lots of different cast and HD mounts for them. You could make your own "headboard" out of surface mount LEDs of your choice. You could do the same thing with Sound Off.
I recommend going over to Strobes n' More . com and comparing the lightheads, beacons and minibars. They stock everything we are discussing and they have low prices. Compare everything with and without the 600 rota-beam, intersector, beacons, mini bars etc and see what the most bang for your buck is and what suits your taste in mounting.
bjwilliams
