fordtruck661
Hi All,
I just purchased a Whelen SmartLogic flasher to install into my truck. I have never set one of these up so I'm going to be learning as I go. A few questions I have before I get started:
I got the photocell with it but am confused as to how to hook it up. I see that it has a + & - for the photocell on the flasher but on the instructions it says to hook it to ignition power. Hooking it to the flasher would be constant power, Or should I install a relay to turn on and off the flasher? Also I'm assuming the low power wire from the photocell just goes to the input I program as low power?
I also is there any way to change a input to be ground activated? My truck has a wire that goes to ground when in park, yes I can use install a relay to make it 12V but if I can skip that step it would be nice.
Any help or Tips would be much apricated!
