Whelen Universal LAW dimensions?
firebuff17
776
CT
F41DD58B-EF92-417A-8EED-ED4A33228CE9.jpeg I am looking for the dimensions of the bulb for the LAW.
I have a lead on a system but after closely looking at where I want to install it I may not have enough room to mount the base of the bulb.
I am looking for the depth including the foam gasket from mating surface to “outside” depth and also from the gasket (not including gasket) to top of bulb. I have included the bulb in question and also a crude marking to describe the measurements.
Thank you
firebuff17
776
CT
Thank you but no.
I took a chance and ended up buying the system on the bay that I was watching.
Received it the other day but have not had a chance to measure them to see if it would fit yet. Family, along with myself, ended up getting sick. Took 3 of us out for over a week.
Hopefully tomorrow will test it and measure it.
octoberguy77
975
Indianapolis, IN
Thank you but no.
Hi, if it doesnt work out I may be interested in it. Just let me know
firebuff17
776
CT
Octoberguy77
Sorry but I will be holding onto these.
Opened the box and the flasher, 2 heads and (2) 20 foot cables all looked brand new. The bags were opened but everything looked flawless. Must have been opened for testing before sale or decided not to be used.
But I measured and actually installed the heads this am. It was a tight fit but they fit perfectly. Was able to get the head right in the middle of the reflector for optimum output. Ran out of time but will mount flasher and run cables tomorrow am.
octoberguy77
975
Indianapolis, IN
Octoberguy77
No problem and thanks for your consideration
Reactions: firebuff17
GSPS629
