Mike5959
I recently bought a cvpi and someone cut out the supplies and left the heads. I do have one set complete. I was wondering if I could parallel a pair to one supply or if I could rig something else up to power them.
If I very quickly tap 12v they flash. I can tell it's too much to I have t done it again. Wasn't sure if solid state flasher would switch fast enough1 supply will not run more than 1 head. It is a current limiting supply so any higher current draw attempts would just result in dimming both heads
They are pretty much useless without the flasher or someone willing to build you an power supply. It could be done but it wouldn't be practical
