Whelen WeCan switch questions
2nd2none
28
NY
I've been looking for a 3 or 4 position slide switch for my POV. If anyone knows of where I can find more options please let me know. All I could find is the Whelen WeCan. The 6 button unit is a good option I can use as well.
Now to my question. I am totally clueless on how this system works, can the switch itself be used without using the controller, or does this switch have to run through the controller to work? Work on Whelens IONs and other equipment that doesn’t need to run through a circuit board
Bvfa23
147
Depew, New York
The WeCan unit you are referring to will only work for WeCan Lightbars.
If you want that size of a switch pad then the PCC8R with its remote relay module is the way to go.
I would recommend the Whelen PCCS9RW, That unit has a 3 position slide switch and 6 other switches for what ever your imagination can think up.
Just my 2C
Constable4016
