Wiring Diagram for 2 Whelen IONS to 1 switch
JakeNShake121
22
NJ
So.. I will be installing 2 Whelen Ions to 1 switch. I was wondering if anyone had any wiring diagrams for this. I made a few myself with one of them just using a relay and the other using a fuse box. Just wanted to see what you guys had. I'll add more information if needed.
why on this green earth would you need a wiring diagram...
they are leds, not 100 watt hella's
you connect the power together, ground as close to each light as possible and connect sync wires...and run the power to a switch
am i missing something? is there some trick your trying to do with them?
o_O
covert
