Wiring diagram - Tomar 925 Alternating Flasher
Good morning all,
I tried the search function; found nothing pertinent.
I am trying to locate a wiring diagram for a Tomar 925 alternating flasher. It is attached to a hacked Federal Signalmaster SML-2 that I received in a box of 'misc. lighting equipment'. It has eight different-colored wires coming out of it. I know I've seen a PDF for this flasher somewhere before, but I tried Google and Tomar's site, and have had no luck. I found one on Google, but it is in Japanese, and in particular, I want to know the function of the White wire (it is the only one i cannot extrapolate from the pictures) before i start experimenting. I've attached the Japanese version of the diagram.
Thanks in advance!!
David
925 Alt-Flasher - Japanese.pdf
  • 925 Alt-Flasher - Japanese.pdf
MtnMan
1,533
Eastern PA
One of the diagrams shows the white wire switched to +12V, so it won't hurt anything to go ahead and try it. I expect it's a flash pattern change or steady override.
Cpierce3
1
Canada
the PDF won't open is there anyway it can be re posted ? just picked up my first 925 and need the wiring diagram for it
Jesseclark2448
