My department purchased 8 SOS Nforces to be used on a rapid response EMS unit. There are two located per side and are dual Red/White with the capability of solid or "steady burn" white scene lighting. I am connecting these units through a 12 head LED flasher to sync all units with 4 LAW's. The NForces must be in slave mode by connecting the white wire to ground for "flashing r/w" but must be connected to power for "steady white light".
The end goal is that if the lights are flashing and I choose "right scene lights" those two will stay solid white while the rest flash AND if all lights are off and "right scene" is activated they will turn on solid white.
Is this possible? Relays? If so, could you include a simple diagram. Thanks for the help in advance!
Greg
Greg
