X pattern on Whelen Linz6s wiring?
xcrownvicx
209
New Jersey
Has anyone ever done the x pattern on linz6s without using a external flasher. For some reason I can't seem to get it. The farthest I've got is all the four light heads completely flash but no x pattern. Thanks.
Zapp Brannigan
May 23, 2010
3,580
Don't see why its not possible, just get two lightheads onto Phase I of the pattern, and the other two to Phase II, then link together all the sync wires.
Edit: My truck has 2x TIR6 and 2x LINZ6 Sync'ed in X-type pattern.
7,072
Tunkhannock, PA, USA
If you have all of them flashing simultaneously on the same pattern, just advance 2 of the lightheads 1 more pattern... As previously stated, Whelen lightheads have Phase 1 & Phase 2 of each pattern one after the other... So take 2 of your lightheads and tap the pattern wire... If that takes it to a different flash pattern, touch and hold the pattern wire, that will make it go back wards through the patterns...
NFD-102
1,083
NW Connecticut
In order to move onto phase two, make sure all of the lights sync wires, the gray ones, are connected. Then you can tap the purple and white wire to the positive wire on both the upper left and the bottom right.
Zapp Brannigan
May 23, 2010
3,580
Yup, just like I said!
May 25, 2010
7,072
I was assuming that he has all the sync wires connected... lol But you know what they say when you assume... lol
xcrownvicx
209
New Jersey
Thank you for everyone that helped, I finally got it. I just was wasn't understanding the phases. Now will every pattern do a phase 1 and 2 pattern?
Jesseclark2448
