hitman38367
Before I start with my question, yes, Zapp, I have used the search function and came up empty.
Ok, on with the question. I have a SS2000SM that I will be using to control everything, however, I will not be using the siren amplifier for the actual siren functions that it can produce. I will have all siren/sound tones disabled completely with no speakers hooked up to the amp. The manual states that Pin 6 of the control harness is recommended to be connected to a ignition sense source and fused for 20 amps. I am not so much worried about the ignition sense source but I am scratching my head about the 20 amps. So, that being said, my question is this. If I am not going to use the siren amplifier at all and all siren functions will be completely disabled, do I still need to use a 20 amp source or can I drop the amperage input since all that the power source will need to push is power to the control head for the most part?
