100 vs 200 WATT
Dragon
52
0
Mississippi
How do you determine if a PA300 is 100 or 200 watts?
Looking at the install manuals posted on line the 69001-69004 are 100 watt.
Mine has a tag on the bottom that just has PA300.
The car is a 2000. I would guess the siren was acquired new that year if not older and reused from a car going out of service.
There are several threads on this very topic on this board and the archive board. TSFIYF!!! IIRC, a "B" is required somewhere on the model number sticker.
Because of the way the equipment is mounted in the car. 2 radios and a light switch box stacked on top of the siren. I dont want to take all that apart until I know if it is 200 watts or not.
From the answer above I have the MSC option which indicates 100 watts.
I found a PA300 in our "dead stuff" pile that had the MSB option. So I am sure now I have a 100 watt version.
Too bad. I have two speakers that will go unused.
Some PA300s have only one speaker output for each type of speaker - one 58 watt output and one 100 watt output. These sirens are only capable of running at 58 watts or 100 watts.
If a PA300 has outputs for two 100 watt speakers, it should be capable of running at 200 watts.
The MSB PA300's that I own use just two pins in the twelve-pin connector for both speakers, which are to be connected in parallel.
rwo78 - If it erks you so bad that I did not search first then pass my topic by. No need to be snippy.
From your first response that answered my question. B means 200. I have a C. I know this from taking a mirror and reading the sticker on the bottom. I did not take it out to take pictures for the reason listed above. But I did state that I know now I have a 100 watt.
So my project of adding another speaker is dead in the water.
nwlanham
