firstresponders
NEW IN BOX
The RECT 37 series sealed beam lamps are 100% watertight and features a chrome coated reflector. It is molded from Lexan and has been designed to fit all popular emergency vehicles. The RECT 37 is furnished with a drill template, gasket, and mounting hardware and can be used with all TOMAR power supplies or halogen controllers.
RECT-37-SS-RED/CLEAR QTY3) $35 EACH, $90 ALL
RECT-37-SS-RED/BLUE QTY2) $35 EACH, $70 BOTH
RECT-37-HWB-BLUE QTY (6) $35 EACH, $200 FOR ALL
RECT-37-SS-CLEAR QTY2) $35 EACH, $70 BOTH
RECT-37-S-RED/CLEAR QTY2) $35 EACH, $70 BOTH
RECT-37-HS-CLEAR/AMBER QTY2) $35 EACH/ $70 BOTH
RECT-37-SS-BLUE QTY: (5) $35 EACH, $160 FOR ALL
RECT-37-S-BLUE QTY5 $35 EACH, $160 FOR ALL
RECT-37-HWB-AMBER QTY5) $35 EACH, $160 FOR ALL
RECT-37-HS-CLEAR/AMBER QTY1) $35
RECT-37-SS-AMBER QTY3) $35 EACH, $100 FOR ALL
RECT-37-SS-RED QTY3) $35 EACH, $90 FOR ALL
RECT-37S Single Strobe
Features a single linear strobe lamp. This configuration has the highest intensity of all 3” x 7” lamp models. [SIZE=7pt]RECT-37SS Dual Strobe
Features two strobe lamps and can be used with any TOMAR strobe power supply in simultaneous or alternating flash operation.[/SIZE] [SIZE=7pt]RECT-37HS Halogen/Strobe
Features a replaceable #890 automotive 12V halogen lamp rated at 27 watts and a nonreplaceable strobe lamp.[/SIZE] [SIZE=7pt]RECT-37HWB Halogen Wide Beam
Features two lamps rated at 27 watts each and can be used as a steady burn or flashing lamp. 54 watt power rating.[/SIZE] [SIZE=7pt]RECT-37HNB Halogen Narrow Beam
