I have just got hold of a 1966 Dominion Auto catalogue.
It is marked Catalogue 66 so I assume it means 1966.
I will try to scan the warning equipment pages as soon I have an opportunity but until then I will state the model numbers here.
Model 357, 2 sealed beams, 70 fpm, 10” diameter, 11 1/2” height, red, amber, blue & crystal.
Model 358, 2 sealed beams, rheostat to adjust flash rate (rheostat 76-5900), 10” diameter, 11 1/2” height, red, amber, blue & crystal.
Model 377, 4 sealed beams, 70 fpm, 10” diameter, 11 1/2” height, red, amber, blue & crystal.
Model 362, 2 sealed beams, 70 fpm, 10” diameter, 11 1/2” height, half red/half amber.
Model 74-5001, high base to clear roof mounted siren, 2 sealed beams, 70 fpm, 10 1/4” diameter, 15 1/4” height, red, amber, blue & crystal.
Model 378, black baked enamel, 4 sealed beams, static flashing (flasher 115-12V), 8 1/2” diameter, 8 1/4” height, red, amber & blue.
Model 379, chrome plated, 4 sealed beams, static flashing (flasher 115-12V), 8 1/2” diameter, 8 1/4” height, red, amber & blue.
Model 374, revolving reflector lamp, bright anodized aluminum high base, magnetic mount, 6” diameter, 7” height, 3 magnets, 10’ cable, red, amber & blue.
Model 375, revolving reflector lamp, bright anodized aluminum high base, permanent mount, 6” diameter, 7” height, red, amber & blue.
Model 352, revolving reflector lamp, low base, magnetic mount, 6” diameter, 5 3/4” height, 3 magnets, 10’ cable, red, amber & blue.
Model 354, revolving reflector lamp, low base, permanent mount, 6” diameter, 5 3/4” height, red, amber & blue.
Static flashing lights (bee hive type):
FS350, plastic lens, flasher & switch, 5 1/8” diameter, 5 7/8” height, red, amber & blue.
FS360, glass lens, flasher & switch, 5 1/8” diameter, 5 7/8” height, red, amber & blue.
1156 bulb, F632 flasher, 5920 switch.
350, without flasher & switch, 5 1/8” diameter, 5 7/8” height, red, amber & blue.
360, without flasher & switch, 5 1/8” diameter, 5 7/8” height, red, amber & blue.
1156 bulb.
FS355, plastic lens, flasher & switch, 5 1/8” diameter, 5 7/8” height, half red/ half amber.
74-4000, plastic red lens.
74-4001, plastic amber lens.
74-4002, plastic blue lens.
74-4003, plastic half red/half amber lens.
5 1/8” diameter, 5 1/8” height.
74-4008, without flasher, half red/half black.
74-4009, with flasher & switch, half red/ half black.
FS796, die cast two-way lamp, black baked enamel, 7” diameter, 8” height, 3” depth, red, amber & blue.
1156 bulb, 180 flasher, 5920 switch.
796, without flasher & switch.
778, black baked enamel, angle bracket, 7 1/2”, red & amber.
1156 bulb.
779, flush mount, 9” diameter, red & amber.
1156 bulb.
74-4501, flush mount, single contact, 7 1/2”, red, 1156 bulb,
74-4502, flush mount, single contact, 7 1/2”, amber, 1156 bulb.
74-4503, flush mount, double contact, 7 1/2”, red, bulb?
FS790, police stop lamp, 7” diameter, red lens with police stop text, flasher & switch.
790, police stop lamp, 7” diameter, red lens with police stop text, without flasher & switch.
FS824B, snow plow lamp, 6” diameter, 4412 sealed beam, blue lens.
17VFF, volunteer fire fighting lamp, 4” diameter, 1141 bulb, amber with VFF text.
Sirens:
368 (Federal Signal WL)
369 (Federal Signal VF)
380 (Federal Signal V)
381 (Federal Signal 28)
382 (Fedral Signal WLRG)
I hope that this information will help some identifications.
Michael
1156 bulb.
1156 bulb.
1156 bulb.
Sirens:
Michael
