fordtruck661
fordtruck661 said:This is my truck with 6 LED Hideaways I also made the 6 switch panel.
NFD-102 said:nice...what do you use the lights for. I am also out of CT welcome to ELB
Ren12 said:I like the rear synch. What type of LAW's did you use?
lafd55 said:Very nice. Me being from New York I will say that is very NYSP of you, lol.
CRASH303 said:Looks great. Where did you run the wires at from the rear to the switch panel? I have a 2000 F250 and had to drill out a hole at the lower rear cab for my strobe cables.
Eric1249 said:Wouldn't the plow block the amber to the front?
My f350, 450, 550 all have a pre drilled hole below the vent with grommet on both sides from factory. All superduties have itCRASH303 said:Looks great. Where did you run the wires at from the rear to the switch panel? I have a 2000 F250 and had to drill out a hole at the lower rear cab for my strobe cables.
Flashguy said:The rear sync looks great! The front amber for plowing is good...for FD not so good (not that you had many options.) ETD has a horrible reputation on here...keep us posted if you have any failures.
