2001 silverado install
Shawn L
Premium Member
92
Corbett, Oregon
here is my truck I put it together a few years ago, it gets used for a variety of uses, its also my demo truck.
Lightbar specs:
Code 3 MX7000. custom rebuild by me from the ground up
Upper Level:
6 high speed rotators 2 amber, 2 red and 2 clear, 2 diamond mirrors, 2 flat mirrors and 2 <> mirrors
Lower Level Front:
2 clear intersection sweeps, 4 takedowns (Flashing) 2 amber over amber ledx heads, 2 red over red ledx heads
Lower Level Rear:
8 light ledx arrowstick, 2 Persuit lights w/ amber bulbs, 4 red ledx modules (over arrowstick)
code 3 new style plastic feet with Whelen (4) LIN3 red heads installed on feet.
Front body:
4 hideaway Strobe tubes, 2 amber (inside DRL area) and 2 clear ( front turn signal lights), headlight flasher, 2 amber and 2 red Whelen TIR3's (grille) 2 red Whelen TIR3's in the unused portion of the headlights facing the sides.
2 amber clear LX4's amber/clear heads on the sides of the push bumper
Rear body:
4 strobe lights in the rear lamps, 2 in the turn signals and 2 in the brake light portion, 2 7x3 tomar strobes mounted in the tool box. 2 whelen LIN3's mounted to a license plate bracket. (these are flashing warning lights, auxillary brake lights and rear facing fog lights)
Interior:
D&R electronics SUV console w/ fold down armrest / notepad, fed sig LED littlelight
Controls:
from top to bottom:
Unitrol 8101 siren/switch controler
top row switches: (all are a On/Off/On rocker)
#1 Left amber HAW strobes front and rear, #1 right amber HAW strobes front and rear, + front clear Haw strobes and rear red strobes,
#2 Left headlight flasher, #2 Right headlight flasher + Takedown flash
#3 Left takedowns, #3 Right takedowns + left alley
#4 Left momentary for siren hone change, #4 Right right alley
Progressive Slide Switch:
Position 1 amber rotators, amber rear sweeps, amber front led's in lightbar, arrowstick flash activate
Position 2 red rotators, red front and rear led's in lightbar
Position 3 clear front intersection sweeps, clear rotators
Code 3 narrowstick control head
Unitrol 330 switch pack
progressive slide switch:
Position 1 Amber leds in grille, and sides of push bumper
Position 2 Red leds in grille, and side headlight leds, rear red licence plate leds
Position 3 2 red rotators, red front and rear led's in lightbar, Position 3 clear front intersection sweeps, clear rotators
Shawn L said:
Front body:
4 Strobe tubes, 2 amber and 2 clear ( front turn signal lights), headlight flasher, 2 amber and 2 red Whelen TIR3's (grille) 2 red Whelen TIR3's in the unused portion of the headlights facing the sides.
Can you clarify this statement with perhaps a close up shot and maybe a picture/video of it on? I am very intrigued.
Thanks
blue 70chevelle:
if you look at the pic of the passenger side, right above the amber reflector portion of the parking light there is an empty section in the headlight where it wraps around, I installed the tir3's well before the advent of the vertex and hide away led systems, i just cut a square hole and epoxied the heads inside the headlight housing, facing the sides.
jrw14493:
My company has several contracts, I work with 2 towing companies and provide roadside service, including AAA, I use the truck as my demo vehicle, and I use it for oversize load escorts occasionally, as my uncle owns a logging company and has 2 lowboys. I made a skid unit for the bed that has the over size load sign, and flags mounted to the rack.
That truck must have 6 million miles on it with all that driving.
just hit 120K I have other vehicles that get driven buy the employees, this is MY truck and i dont want to build it anytime soon the truck that the silverado replaced had 425K on it when i sold it
blue70 chevelle I added pics of the tir3's installed by the headlights, of cource this would be easier to do today with a pair of vertex, but I did this well before they relesed the vertex, or any hideaway led for that matter. I also did a install on a silverado for a police dept where I removed the cargo lights by the CHSML and installed 2 blue tir3's the truck also got rear haw strobes and 2 tir6's on the back of the tool box
jrw14493 said:
Define "variety of uses"
What difference does it make? Look at the install and the vinyl. . . The last thing we need is anymore people starting s#*tstorms over the uses of people's lights.
BlueOrange
