Newton15
Having problems with an install on an 03 chevy impala civilian version, the flasher is a Soundoff signal ETRR00CG ground side drl compatible. Followed the instructions included but the headlights would not flash. When supplied with power and ground the flasher relay would click. There is a pink wire which comes off the flasher but is not mentioned in the directions, so Im thinking the pink wire might need to be hooked to something. Any suggestions or ideas would help. Cant contact sound off signal tech support until monday am.
Thanks Ryne
Thanks Ryne
