2004 GMC Canyon Ideas...
gfpd26
Greenville, IL
Ok... I bought a 2004 Canyon extended cab 4x4. Great midsized truck. I am using it mostly for Fire-Rescue-Hazmat calls on 2 different departments . But it is will also be used for LE for Reserve Police, mostly for special details and traffic on a state highway. Currently it only has the powerarc on the dash.
Blue is for fire and red will be for police with the blue used also...
Here is what I am thinking right now:
Front:
Wig-wag
Clear strobes in upper turn signals
Red/Blue chameleons in grille
Powerarc dl-12 blue on dash
Tomar T-led in red above RVM (it fits)
Sides:
2 blue 3led pimp pods on ends of running boards
1 red in center of running boards
Rear:
2 single blue talons in upper corners of window
1 single red in center of window
911ep TD in Amber on bottom of window
2 blue pimp pods under tailgate
traffic backer or strobes in taillights???
Siren will be my Wheleln Alpha 12Q. Yes I know people will bitch with it in "Q" mode for police work, but I do not care. Thats what it is going to be.......
I'm open to ideas for changes. I already have all the stuff except the corner strobes, and red talon, but they are coming. Ideas Ideas Ideas... lets here them.....
[Broken External Image]:http://i242.photobucket.com/albums/ff67/chief-homer/Mobile Uploads/jpeg_reencoded.jpg
I would get somthing on the roof. A minibar would look good. If your getting a Talon you can get the Avenger its the new version and its brighter. I love the Q siren I use it all the time for EMS response with my 1510 Grover.
JaBradt85 said:
Thats quite the list of stuff. I have a Colorado and that is going to fill your inside up to where you wont be able to see.
Really? I wouldn't think it would be too bad.I did a mock-up the other night and it looked just fine.
As far as a mini bar, I am trying to stay away from a lightbar on the truck. It has been thought about, but just want to try something different with this one.
i think it sounds like a solid setup. i'd def. consider moving one of the running board pimp pods up further towards the front for intersection visibility.
altho i think the setup sounds perfectly fine, a variation of it that i'd consider would be moving some of the talons and the t-led around (i personally would put 1 red and 1 blue talon up front on each side of the RVM and then move the t-led to face the rear on a slow flash pattern. then u could play around with the 2nd/extra blue talon that you'd have laying around.)
imo, depends on the budget...if i could afford it, i'd do HAWs b/c of the punch, but at the same time, the TLF would be sufficient (imo) b/c u have the other sources of rear lighting.
gabyluis_1
