kadetklapp
Helping a guy I work with set up a 2007 Impala 9C1. Does this car have a PCM controlled HLF like the Charger does? For some reason I was thinking it did.
kadetklapp said:Helping a guy I work with set up a 2007 Impala 9C1. Does this car have a PCM controlled HLF like the Charger does? For some reason I was thinking it did.
Yes, standard on the Police Package 06-10. I'd recommend the SoundOff ETHIMPØ-Ø6+ or the Whelen SSFPOSI6. Both will work great, but the Whelen gives you a few more patterns.kadetklapp said:Ok thanks. And this is a standard feature? He's confused about what, if any flasher he needs to order.
This happens because the PNP flasher you install is what provides the signal (it's a ground signal) to the BCM to flash the tails. In overriding the flasher operation by hitting the high beams, you also disable the signal to the BCM for the TL flash.RL1 said:One odd thing is that the TLF will not work when you override the wig wags with your high beams.
