Just bought 2 SOS Undercover LED inserts. Anyone have pictures or the best idea to mount them in the front headlights? Seems to be the best to do it in the low-beam area but I just don't know the best spot to drill the hole.
I would recommend not putting them in the low beam section of the headlight. They will be useless when the headlights are on. I would put them in the turn signal portion. Also, mount them close to the factory bulb as this will give you the best output and will be the best placement in the reflector
I had an 07 Impala at my last dept and the strobes were in the low beams, coming up from the bottom. Looked great during the day, but was washed out at night. Same with the other 07 that had them mounted sideways. I've seen them placed in the high beams but 1. looks totally stupid, 2. stupid to have strobes and wig wags in the same housing, and 3. defeats the purpose of 'intersection warning'.
you think putting it more forward in the housing would make for little more side warning? obviously it isnt going to be the best side warning but just a little something.
Yes, which is what I meant to say in my first post. It needs to be far enough forward to be seen from the side, but far enough back to not melt the lens and still fill the reflector. I added a dash light, which covered my headlight sensor, so I just turned my lights off every time I got in the car on day shift. It really helped the strobes be seen during the day.
