2007 silverado classic quad cab
Jhart911er
67
North east pennsylvania
Ok so I keep adding lights and decided it was time to put in a better switchbox. I am very anal about my truck and don't want alot of holes in the dash or shit screwed to the floor.....so this is what I came up with....
I mounted the galls xl200 switchbox in the overhead console. It fits so good that there are no mounting brackets just some minor modification to the xl200 and it actually snapped right into the existing ridge in the console. I ran a bead of silicone around the backside of it just to be sure but trust me this thing isn't moving unless it gets punched, it's tight!!!
In the cab I also have a 40 watt UHF spectra A9 head with PA/ siren but have the siren disabled as I no longer am a line officer. This also was given a strategic mounting location. I used an extended VIP accessory mounting bracket(for the length) and screwed it to the plastic heating duct running under the dashboard. I have plans in the future of changing this to a VHF 110 watt(which I have) and adding a cdm1550ls UHF remote mount( which I also have but need some parts to complete it) at which time I am going to attempt to custom build a small equipment console from some sheet aluminum or stainless and flush mount both radios inside
As far as lighting I don't think it's overboard but here we go
Front:
Axitech stealth SV56 interior split visor bar all blue with clear TD
Whelen 5mm slim miser all blue in center just below SV56 just to fill in a bit
2-whelen 500 series lin6's in blue recessed behind grill on custom made brackets from chuck at pike county communications ImageUploadedByTapatalk1335710856.206967.jpg
REAR:
Strobes N' More E66 TA all blue mounted in rear window
Still to be added
Whelen mirror beams (got em just havnt had time to install em)
Maybe some TIR 4's or lin6's on a LP bracket
2 blue feniex fairies or whelen vertex in back up lights
Any comments or ideas I'm open to suggestions and I'll try to post some more pics and a video later
Thanks
Jeremy
dariusz
