2008 Dodge Charger POV
Amanda
193
NY, USA
So I set up my new car recently, lost 2 TIR6's that I was gonna put in my grille which was a huge bummer, but I have enough coverage as is. I don't have the dash light hardwired, I kept it on the stock plug that comes with it. I'm gonna keep the two sets on different switches so that when I'm on scene I can cut the dash light and use the lower lights still for warning.
Whelen Avenger
2 PAR36 Axixtech lights in blue.
Video (make sure to watch in 720p (HD))
Photos:
looks good, no rear warning???
not sure i like the switch mounting. if you are on a scene somewhere, i personally want all available lights to protect my vehicle. i wouldn't cut the dash light off for any reason on scene. if ANYTHING i would cut the fog lights and keep the dash light on.
also need some rear warning.
No rear warning as of right now. I'm working on it. Probably just going to do 2 TIR3s on the LP on a bracket and possibly 2 single head avengers or something like that on the back deck wired into the same switch.
The install had to be as no holes as possible and that location was the most practical because I am sure I could get a new one if I looked in the right places.
I am about to purchase an 07 or 08 charger. How easy was it to install the PAR36's and replace the factory fog lamps? And how easy is it to get through the firewall for running power in it?
I didn't have fog lamps it was the rubber inserts, which were easy to pop out. The firewall had a really small sized grommet through it that I had to cut a little slit into to fit the extra wire in. It was a tedious task to say the least.
Not a lease, but a written agreement between myself and my cosigner on my loan that I wouldn't put holes everywhere. Haha.
looks good. You do need some rear warning. Thats to bad that you have to make sure that it is a no hole install but just do the best you can with it.
I've done some work to the car over the past few months.
First, installed a Sound Off Interior Pinnacle to the front:
Second, I got steelies:
Third, tints:
Whole car, no lights.
[Broken External Image]:http://img707.imageshack.us/img707/8328/18363915715688939471377.jpg
As of July 3rd a deer ran out and it's head met my headlight then his body made some sweet lovin' to my passenger door.
[Broken External Image]:http://img823.imageshack.us/img823/5039/28081118335845241741377.jpg
The passenger door doesn't close and has to be slammed shut. It's safer for it to be in the shop than out on the road knowing that, and I don't need another deer making my car it's splatter shield. While the car is in the shop I'm going to pick up a Setina PB400 and PB7 or PB8 wraps to be installed while the car is already apart.
Sorry about the accident, but it's good that you didn't get hurt!
On the upside, the install looks nice
No, I sold the avenger to someone on the fire department. I was about to start installing (in the next few weeks..) 2 single avengers and a quad dominator in the rear window with the avengers at a bit of an angle and the dominator centered. But that deer rained on my parade.
Jacob S.
