jdip
2009 Dodge Charger SE
I just installed my Uniden 996T with remote head. Scanner is mounted in the trunk and the remote head up front and tapped that power from behind the cig lighter which is powered by the ignition. However the main scanner is currently hooked up to a fuse with constant power from the Rear power distribution center. Does anyone know any fuse I can tap the scanner into that is powered by the ignition. I know there are several in the front fuse distribution block but not sure of any in the rear where my scanner is mounted. Thanks!
