SlickTop Solutions
So, I'm working on an install for a friend as I have time between other work. The issue is with the high beams on the 2009 Toyota Corolla, it would appear that there is no ground or +12 VDC until you turn the high beams on, so with the high beam switch off, there is no way to turn the bulb on by either adding +12 VDC to the hot, or ground to the Neg wire (confirmed using a power probe).
Currently using a Whelen UHF5150.
Wired correctly:
Black - Ground
Red - Fused power (Battery)
Orange - Console switch
Blue - Left High beam bulb
Blue/White - Left High Beam harness
Yellow - Right High beam bulb
Yellow/White - Right high beam harness
White - Spliced in with Blue/White
White/Black - Spliced in with Orange
Brown - not used
White/Brown - not used
White/Violet - not wired
The flasher activates and the relays click when turned on and the +12 VDC goes on and off with the flasher (verified with power probe). The high beam override works and shuts the flasher off when the high beams are activated and the high beams do come on.
I am thinking that I will have to wire in a full time ground to the ground side of the bulbs (possibly with diodes) to get the high beams to flash.
Just need a few folks to look at this and verify I am thinking the right way (Cajun, C2, anybody)
Thanks.
Wired correctly:
Black - Ground
Brown - not used
Thanks.
