2010 Chevy Suburban / Tahoe rear door sense
EVModules
864
Deer Park, WA
Anyone ever worked on a 2010 Chevy Suburban / Tahoe and located the sense wire for the rear doors? I don't have either vehicle to work with yet and want to be armed with the info.
rescue52
386
New York
I'm not sure what wire you are looking for but this might nelp.
DOOR TRIGGER GRAY/BLACK (-) @ DRIVERS WINDOW SWITCH (BROWN 16-Pin Plug) Pin 13
DOMELIGHT SUPERVISION GRAY (+) @ BCM, (WHITE Plug) Pin 5
TRUNK RELEASE GRAY (-) (Liftgate), PINK (-) (Liftgate Window) @ BCM, (PINK Plug) Pins 13 and 24, Note #1
*Note #1: The BCM, (Body control Module) is located under the drivers side of the Dash and to
the Left of the Steering Column
May 24, 2010
325
East Longmeadow, MA
LF Latch BROWN (-) AT DRIVER DOOR MODULE IN DRIVER DOOR
RF Latch BLACK/WHITE (-) AT PASSENGER DOOR MODULE IN PASSENGER DOOR NOTE:MAY ALSO BE WHITE/TAN ON SOME MODELS
LR Latch LIGHT BLUE/BLACK (-) AT BCM MODULE UNDER DRIVER DASH PLUG C5 PIN 15
RR Latch LIGHT GREEN//BLACK (-) AT BCM MODULE UNDER DRIVER DASH PLUG C6 PIN 14
Trunk Trigger PINK/BLACK (-) AT BCM MODULE UNDER DRIVER DASH NOTE: MAY ALSO BE AT LIFTGATE MODULE IN LEFT REAR QUARTER PANEL IF EQUIPPED WITH POWER HATCH
Hood Trigger PINK/BLACK (-) AT BCM MODULE UNDER DRIVER DASH
tliberty
