2010 Jeep Liberty
WNYEVS
Brockport NY
Yesterday we worked on a 2010 Jeep Liberty. Surprisingly, it was very easy to work on. There was lots of room to work in and all the trim pieces were easy to remove.
Front:
2 Blue Axixtech SE3's in the Grille
2 Blue Mini Phantoms (provided by the vehicle owner) mounted with custom made brackets that mount under the headliner.
Rear:
32" Microman Industries Arrowstar Bar all Amber.
2 Outlet Power Inverter
Interior:
Brookings Industries BR-990 Digital Switchbox
Sho-Me Flasher for the Microman Arrowstar G3 Bar
GRE PSR-600 Digital Scanner
[Broken External Image]:http://www.wnyevs.com/DSCN0517.JPG
[Broken External Image]:http://www.wnyevs.com/DSCN0518.JPG
[Broken External Image]:http://www.wnyevs.com/DSCN0525.JPG
[Broken External Image]:http://www.wnyevs.com/DSCN0519.JPG
[Broken External Image]:http://www.wnyevs.com/DSCN0520.JPG
[Broken External Image]:http://www.wnyevs.com/DSCN0528.JPG
[Broken External Image]:http://www.wnyevs.com/DSCN0521.JPG
[Broken External Image]:http://www.wnyevs.com/DSCN0533_op_665x498.jpg
[Broken External Image]:http://www.wnyevs.com/DSCN0522.JPG
[Broken External Image]:http://www.wnyevs.com/DSCN0530.JPG
[Broken External Image]:http://www.wnyevs.com/phantom.JPG
[Broken External Image]:http://www.wnyevs.com/DSCN0523.JPG
Nice ride, and very neat work.
Although I personally don't like mixing LEDs generations, and am not a big fan of headliner front lights (although they are very fashionable these days in the US for slicktops).
Still, a very neat installation.
Isn't it bothering not to be able to see the arrow stick control panel ?
Yes, how did you mount the mini phantoms? That light gives good bang for the buck.
Oh and tell me more about that forest green 1994 (right?) Taurus S.H.O.! Please tell me it is a stick! The only way that car would be better is if it was the blue color!
It looks good. The flash back from the lights looks kind of bad but it might just be the vid. Other then that looks good.
The install looks good Carl. That Microman bar seems to really cut through the tint.
Very clean, very nice install. Nice touches on wiring through the body panels. I plan on upgrading to the Microman 32" in the back glass of my 2004 Liberty.
Thank you everyone for the comments.
treycash said:
How did you mount the mini phantoms?
We took them apart and drilled a hole in the top. Then we took some aluminum stock and bent it so the light would face straight. The aluminum mounts under the headliner using the sun visor bracket.
Although I personally don't like mixing LEDs generations, and am not a big fan of headliner front lights (although they are very fashionable these days in the US for slicktops).Still, a very neat installation.
The arrow stick controller can still be seen. That is why we put it upside down so it is oriented the same way as the bar.
That is my buddies. I think it is a 94. It used to be an automatic but he converted it to stick. He loves it!
The Flashback is a little extreme. I am going to try and get him to convert to 2 Microman Microstarbar G3's w/ custom made shrouds.
Thank you.
I have been talking with the owner and he is thinking about putting something in the rear side windows. I am thinking an 8" R/A Microman Microstar G3 Bar on each side.
Thanks for the comments. Keep em coming!
TheGatekeeper said:
How do you like the Brookings switch panel ?
I like this panel. I think it looks good and I love the soft touch buttons! It was fairly easy to install.
What I dont like about it is the ginormous connectors in the rear of the unit.
I have yet to install a PCC8R but I think It would have been easier for this application.
The customer is very happy with the brookings panel though.
frenchie90
