Alaska Limousine
This POV I built is owned by an Alaskan City reserve police officer NOT A COMMISSIONED Police Officer. This is Privately owned and does not/ and cannot have Red/Blue lights on it.
Please do not swamp my thread informing me of the color of my clients lights.
The vehicle has the following installed:
Starting from front to rear-
-Pair Light Force Striker "Moose Lights"
-Pair Whelen TIR3 Amber LED Signal Alert pattern Bumper mounted (also used as secondary turn signal)
-Setina Pushbumper
-Opticom 3M Coded/Secure Traffic Pre-Emption power supply with Whelen Single Dashmiser Strobe with IR Lens mounted behind grille
-Federal Signal Rumbler system
-Sound-Off High Beam Flasher Unit
-1 EA Whelen SA314 100Watt Siren Speaker
-Pair Whelen Clear Hide-a-way Strobes permanent mounted in Corner parking lights with heavy gauge marine wire & connectors
-Set of Heavy Duty Rubber Mud/Splash Guards in wheel wells
-Pair of Sound-Off Interesctor Amber LED's mounted under mirrors (also used as a secondary turn signal)
-Pair of Whelen Mirror Beam Strobe 500 Series Clear/Clear
-Whelen Inner Edge Lightbar 8 Amber LED & 2 Clear Take Downs
-Eyewitness Police video dash cam & overhead control w/LCD monitor and wireless microphone
-1 EA NMO mounted 3/8 Wave VHF 110 Watt Antenna
-Whelen 8 LED Traffic Advisor (each outter-most LED is also a secondary turn signal)
-Whelen deck mounted 500 Series Strobes Red/Red using a Whelen Talon housing around 3rd taillight
-1 EA Antennex VHF 50 Watt low profile antennas one for Motorola XTS5000 convertacom
-1 EA Antennex UHF 50 Watt low prfile antenna
-1 EA Trimble GPS antenna
-1 EA Antennex Low Profile 3G Wi-Fi Antenna
-1 EA Antennex Low Profile 802.1 WLAN Antenna
-Sound-Off Bask Flash unit
-Pair Whelen Hide-A-Way strobes mounted in tail lights Red/Red
Troy Console CC-MC-25 has the following:
Master Switch
Barrel Key Switch (to disable all non-factory installed equiptment functions)
Motorola DEK siren/PA controls
Motorola Astro W9 control/display head
2 EA Motorola AUX Switchboxes
Whelen Traffic Advisor controller TACLTD1
Whelen DIP8 LED Diagnostic Strobe Indicator Panel
Troy AC-INTHBH-G beverage holder with rubber grommets
Troy FP-TICK 3" Open Stroage Box
Motorola Speaker
Troy AC-ARM MNT 5"x10" Leather Arm rest adjustable
Dash has Havis C-MCB-CV Dual Mic Clip
Console has a side mounted Motorola XTVA (convertacom) for a VHF XTS5000
Motorola MW-800 Touchscreen Computer with DVD-RW, GPS, Wi-Fi, and AT&T 3G Internet Data Air Card w/ external Antennas
Siren/PA & Airhorn is driven by a Motorola Systems 9000 110Watt Siren/PA Amp controlled from the radio control head and also has an electric airhorn with Rumbler feature activation when steering wheel horn ring is depressed.
Trunk has Havis Full width tray that slides out
Whelen ISP188 8 Outlet 180 Watt Strobe Power supply
-Setina Pushbumper
Master Switch
Motorola Speaker
