2011 GMC Terrain with Emergency Lighting
LawMan902
288
FL, USA
I am going to assume this is a leased pov and that's why minimal lighting was installed as to not go drilling holes everywhere. I would definitely suggest getting rid of those split tir4's and go with at least some tir6 if you absolutely must have the split color/flash pattern. Might want to also at least add a license plate bracket for more rear warning, and possibly a 10-75 bracket up front if you are using this vehicle to respond. You've got a good foundation though...
-Chris
fire1
621
Michigan
If this is all the light you are going to put on, I would take the ones in the back side windows and grill mount them. Or is this a way to say I have minimum 360 protection.
May 25, 2010
7,072
Tunkhannock, PA, USA
The 360 rule applies to a roof mounted light of some sort... Technically this set-up is completely illegal in PA... But it all depends on where you're from and how hard the PD in the area(s) crack down on it... Technically My set-up is also illegal... LoL
To the OP... Its a great start, but I do agree that you should add some more to it...
ceavers30
30
USA PA
The vehicle is not leased I bought it. I had strobes and grille lights in my Colorado that I sold. Im waiting to have money to get some LED HAW in the front turn signals and reverse lights. The grille has almost no where to mount anything in it.
Sep 13, 2010
761
Holland, Michigan
Definatly add more rear warning. The grille has plenty of openings to add lights. Get a fender washer and mount it on the back side of the grille when you bolt the light down the fender washer will prevent the nut from pulling thru one of the factory openings in the grille. I would also add a rear LP bracket and some lights. I'd put the rear window leds on the LP brackect if they are waterproof and get some leds with a little more kick to them behind that tint. Otherwise, you have a good start to a bad ass lookin suv. Trick it out.
LawMan902
288
FL, USA
Watching the video again, the lights in the rear look like some type of LIN4 heads. They would be perfect for a LP bracket, and I would reccomend some type of warning bar for the rear. I just picked up a 6 head Rocket X warning bar/ta (6x tir4 heads) from "tom" on here for $160. It is an awesome light, has warning and ta patterns, and punches through my limo tinted rear window perfectly. And the price can't be beat... Check it out!
Tom
3,083
Taunton, MA
LawMan902 said:
...and I would reccomend some type of warning bar for the rear. I just picked up a 6 head Rocket X warning bar/ta (6x tir4 heads) from "tom" on here for $160. It is an awesome light, has warning and ta patterns, and punches through my limo tinted rear window perfectly. And the price can't be beat... Check it out!
Thanks for the plug Chris! :thumbsup:
chono
496
Midwest
Try and look for 2 single talons or vipers on the board here. They would be way better for the rear then what you are running now.
If money isnt an issue try to get a warning bar back there.
Ipuvaepe
884
Southeast Pennsylvania
I didn't want to be the bearer of bad news, thanks man!
But yeah. Also the red to the rear is pretty illegal too.
cory y
it All depends on how he uses the lights... For onscene ID purposes, this set up is plenty. For Courtesy lights, its plenty. for actual Responce, its minimal, but if it moves traffic it works.
Less is More
and if it is used for response, the rear lights are plenty. more focus should be on the front half than the rear.
unless this vehicle is going to be sitting on the side of a high speed road, the back is just fine.
May 25, 2010
7,072
HAHA Yeah, I get told all the time about the not so legal nature of my vehicle... But most areas are pretty good unless you screw around with your lights...
nerdly_dood
2,312
Georgia
So they're not amber?
Ipuvaepe
884
Maybe they are but purple colored tint across the top makes it look red by filtering out the green while leaving the red from the ambers and blue from blue untouched? They look red to me.
Not that it matters, technically in PA VFF (who are the only ones who can use blue without red) are not supposed to use any color other than blue, no B/A or B/W just B/B.
Though I have NEVER seen that enforced, and I hope I never will.
ceavers30
30
USA PA
Updating lights in the terrain just ordered 2 mini phantoms blue/white for front headliner, mini justice all blue, and light stick for rear window
Fast LT1
2,018
Sedgwick County, KS
DEAR FUCKING LORD, what the hell is all that screaming and beating in the video, is that supposed to be music??????
bobbyj
298
Bellingham, MA
Hey, do you have any pics of your interior set up? I'm doing an install in one and I'm having some trouble picking the best design.
Also, do you have a radio installed?
StormChase85
