C2Installs
I recently completed two 2012 Impalas for a regional agency. These are going to be used for traffic/aggressive driving enforcement, mostly during daytime, I think. They wanted a lot of visibility when lit up and for the cars to leave an impression. I spec'd all SOS products for warning and they turned out great. Please forgive the pic quality, I used my iPod Touch and Android phone for pics. Pics show both the black and silver car interchangeably. Hope you like them and the detail work.
Videos first: (Sorry, no night shots and low quality from cell phone. I really got to get a camera.)
[Broken External Image]:[URL]http://i499.photobucket.com/albums/rr351/C2Installs/th_VIDEO0050.jpg[/URL]
[Broken External Image]:[URL]http://i499.photobucket.com/albums/rr351/C2Installs/th_VIDEO0049.jpg[/URL]
[Broken External Image]:[URL]http://i499.photobucket.com/albums/rr351/C2Installs/th_VIDEO0048.jpg[/URL]
Now the nitty-gritty:
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0358.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0357.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0356.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0414.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0412.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0370.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0369.jpg
I knew from the start that I was NOT going to do HAWs in the headlights in these cars. Just not worth the PITA! Instead, I sold the customer on my own version of the "Stealth" license place bracket...two white SOS LED3s on 45 degree brackets. I simply mounted them against the LP holder using fender washers and 10x32 machine screws. The result was impressive and really nailed the 45 degree angle. They do not add much straight to the front due to the TIR optics. Overall, I really like how they came out.
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0408.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0365.jpg
While the front was off, I went ahead and mounted the speaker, a SOS 100H unit. The SOS bracket is my favorite for the Impala, and it's stainless steel construction is lightweight and plenty solid. And it won't rust to crap like the other brands. It bolts up easy and just works.
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0367.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0416.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0418.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0417.jpg
I also knocked out the grille lights while the front was off. Two SOS XP63s worked well, but it took a bit of time to get them positioned correctly for max output. They work well, even behind the grille. The XP63's built-in mount was all that was needed and I used screws and spring-nuts to hold them in place. I still think the XP63 is the least-appreciated product in SOS's line-up. It is an excellent lighting choice at a great price, and is very versatile.
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0405.jpg
The SOS Impala Plug-n-Play Flasher was utilized for the wig/wags. No drama, and uses the Impala's wiring.
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0419.jpg
Here is the front tie-in for the grille & LP LEDs. I used standard butt connectors and good heatshrink. Should be easy enough to access if needed.
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0422.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0420.jpg
I put Intersectors on the mirror. Very simple and straight-forward. Impalas are the easiest mirrors to install these on by far. I thought I took more pics than this, but apparently not.
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0424.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0425.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0428.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0429.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0430.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0462.jpg
Additional side warning was accomplished using SOS Ghost Rock lights mounted to the doors. Cables were run externally for ease of install and servicing. I secured the cables using plastic clamps. The Rocks work well here, as they swivel to allow for best viewing angle and the bracket helps reduce flashback somewhat. They also look cleaner than other choices, IMO.
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0427.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0431.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0409.jpg
The rear deck got a Pinnacle interior bar. It is stunning in its output. To mount it, first fit the brackets loosely to the bar. Set the bar on the deck tight to the window. Check the fit. Again. Now mark the mounting holes for the bracket. Now remove the rear deck covering and drill the holes. Loosely mount the bar to the deck using a fastener that will not require you to hold the blind back side. I made a simple metal plate with two 1/4x20 rivet-nuts (nut-serts) in it as a backing plate. Now, re-fit the deck cover to the deck and secure it. Finally, fit the Pinnacle bar tight to the window and bolt it down. It really isn't hard, but for best results, take your time. As an alternative to using bolts to mount the bar, you could use 1" long interior trim push fasteners (fir tree fasteners) to pin it down, allowing for easy removal. You would still need to remove the deck cover and use extreme care in making 1/4" holes for the fasteners, but it would work and be plenty secure, IMO.
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0434.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0436.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0437.jpg
Red SOS LED HAWs were added to the rear taillights. Simple.
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0473.jpg
SOS 385 Remote Handheld siren amp was mounted in trunk behind side-cover on driver-side. I added a PDC block taken off a Tahoe.
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0471.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0463.jpg
Kenwood radio amp and wifi download interface module for Safety Vision camera were mounted under deck. Took some time and was aggravating, but worked out well.
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0475.jpg
I used the seat back's lower mounting plate to aid in routing the wire run and protecting it.
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0476.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0478.jpg
Here is Setina's MUCH improved mounting system for the Impala. One simple plate and three easy holes to drill versus a bunch of cuts in the plastic trim cover.
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0454.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0460.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0461.jpg
Some shots of how I mounted the PITA speaker, PITA mic cradle, and PITA rear seat camera. You do know what PITA means, right?
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0488.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0450.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0452.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0444.jpg
Ok, the customer provided a Galls radio rack to use in this install. I hate them. But, they did not want a console and did not want the communications equipment just screwed down somewhere...this is because their old upfitter plain sucked and did a lot of crappy work. I played with the rack and realized I could invert it and fasten it to the console's center drop. It works well and looks pretty good. Really simplified the interior and made the customer happy. You can also see the Havis docking station. It was a PITA to install, too, due to the Impala's goofy front seat hook-in mounting system.
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0447.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0449.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0448.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0469.jpg
I wanted to mount the 385 RHH controller high on the dash to allow for easy of use by the officer. It took a bit of figuring due to the airbags and limited dash real estate and contours. I finally found a solution in a XP63 bracket. With a bit of fitting, I was able to use it to mount the siren controller's cradle to the dash. I think it turned out pretty well.
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0485.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0481.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0480.jpg
[Broken External Image]:http://i499.photobucket.com/albums/rr351/C2Installs/IMAG0446.jpg
Some shots of how I made the Safety Vision camera and monitor work with the Pinnacle Interior Windshield bar. It was not fun. I will only say I am not a Safety Vision fan. The monitor is huge.
That's about it. I really thought I took more pics...Oh well, you get the idea. Lots of details and two cool Impalas.
Thanks for looking!
Thanks for looking!
