bullfrog4ever
Hey all!! This is my 2013 EC Silverado Volunteer FD POV. After much testing between Feniex Apollos and Cobra T6's behind 5% tint, I decided on Cobra's. This is what I came up with for now, still a work in progress. Let me know what you think so far!! Thanks!!
Current Setup:
Switching:
Custom console made to mimoc a Jotto console with switch panels for OTRATTW Carling switches, run off of up fitter connection from the MBEC panel
Switch Lineup: Master Power DPDT red (runs with ignition or constant hot) 4200 Day/Night control SPST, Aux Brights cutoff SPST, Aux reverse cutoff SPST (the last 3 have green lower leds when power is on and red upper when the switch is hot to match the 4200 green/red functions)
I have the inputs on the 4200 programmed for brights to turn on my Rigids in the fog light pods and for reverse to turn on my rear Rigid with secondary cutoffs for both.
Feniex 4200 w/ bluetooth
Front:
Headlights - Feniex Cannon 120's White
Grille - Rigid Industries Dually Pair Blue w/ Diffused lens in grille running off 4200 headlight flasher
Windshield - Feniex Cobra 2x X 2 Blue mounted in the headliner
Fogs - Rigid Industries Silverado Fog Mount with D2 driving White
Rear:
Taillights - Feniex Cannon 120's White
Window - Feniex Cobra 2x X 2 Blue / Cobra 800 Arrow Amber with custom headliner bracket (needs to be cleaned up, just too lazy to take it out for now)
Bumper - Rigid Industries SRQ2 flush mount Diffused White
Edited To Come (7/10/15):
Replace Rigid blues in grille with 4 Feniex Apollo F12's Blue/White on brush guard. Or 2 Feniex 7x3's (debating, but leaning towards dual color F12's)
2 or 4 (debating on quantity) Feniex Apollo F12's Blue/White mounted to the side of the grille guard for better intersection. Secondary mode will be hooked to turn signals as flood to see while turning at night.
2 Feniex F12's Blue/Amber on tow mirrors. Maybe. (Amber will be running/turn lights)
Whelen UFM8 LED Flasher to sync all flashing - Aquired, But unknown if I'll use yet...
Cobra ILB Blue w/ white flashing takedowns and move the Front cobra 2x to side windows.
Custom switch panel holder for the OTRATTW/4200 control head - DONE
Hook up 4200's HLF to brights.
Walk Around
Current Setup:
Switching:
Front:
Rear:
Walk Around
