bullfrog4ever
So, I got my first big build for somebody other than my fire dept. This is for a large subdivision security department that is part of 2 counties. This vehicle is used for patrol. I guess you could say, are a pseudo police department, enforcing subdivision rules, speed limits, etc and assisting county pd's and fire/ems as needed. So anyways, they've had trouble with several upfitters providing them with shoddy work and shoddy equipment. I stepped in an told them I could do much better and I finally got my chance. They took delivery of a 2016 Ford Interceptor Utility and I got to work.
2016 Ford Interceptor Utility included:
Front Aux warning (Vertex in fog lights)
Front Wiring Prep
Rear Quarter Glass Whelen Ion
Equipment added:
Front:
Apollo Dual Colored ILB Red/Blue w/ Flood override
Cobra 400 Red/Blue
Feniex Triton Speaker
Whelen Police Interceptor Utility Drivers Side Speaker Bracket
Rear:
Cobra 600 Red/Blue
Apollo F12 R/A B/A
Apollo License Plate Bracket
Interior:
D&R Police Interceptor Utility Center Console
Icom 5021 VHF Radio
Feniex 4200 Controller
Storm Pro 200 W
Havis Rear Equipment Tray
Blue Sea Systems 80 AMP Breaker
Blue Sea Systems Fuse Block w/ Ground Terminals
I have the front Cobra 400 mounted to the front bumper with a L Bracket.
The Cobra 600 is mounted on a double L Bracket with 2 nutserts in the rear with 1 slit in the headliner to put it back.
The rear equipment tray is only partially mounted, as Havis keeps neglecting to send everything in one shipment. I've had to call Havis 2 times now. The first time they forgot all the brackets, the 2nd time, they sent half the brackets. So I'm still waiting on the remaining brackets.
Ford also neglected to package the vehicle with all the pigtails. That cause a big slow down tracking the pigtails down since the dealership had no clue what was supposed to be included. Luckily I was able to get all the pigtails needed to complete the project.
I'm also still waiting on the dash cam, radar and a couple console face plates. They've been having trouble through their supplier on getting the equipment on time. For now, it'll be on the road as a supervisor vehicle before it goes on the patrol rotation.
The Apollos F12's are mounted to the license plate mount and wiring is run through next to the license plate lights and then into the rear lift gate.
All the wiring follows the stock wiring path from Ford.
Feniex Triton w/ Whelen Bracket
Apollo ILB Red/Blue w/ Takedown
Cobra 400 Red/Blue
Cobra 400 Red/Blue
Cobra 600 Red/Blue
Cobra 600 Red/Blue
Equipment Mounted to Havis Tray
D&R Center Console
Apollo ILB Takedowns
Rear Apollo w/ License Plate Bracket
Original Front Patterns
Slide Switch 1: Rear Apollo R/A B/A, Cobra 600, Rear Ions
Slide Switch 2: Apollo ILB, Whelen Vertex, Rear Ions, Cobra 600, Rear Apollo (also used for FST with takedowns)
Slide Switch 3 Parked: Apollo ILB, Whelen Vertex, Cobra 400, Rear Ions, Cobra 600, Rear Apollo
Slide Switch 3 Drive: Apollo ILB, Whelen Vertex, Cobra 400, Rear Ions, Cobra 600, Rear Apollo
Now let me just say, I'm not a fan of the final pattern chosen for the Cobra 400, but the customer loves that pattern (I have no clue, they like Cylon lights) and they changed the parked Apollo ILB pattern to that as well. I stressed to them that the original patterns I set are better, more effective and safer, but it's their car and they want what they want. I have it set up to change the patterns quickly. So I'm really hoping they'll decide to change it. I think I'll make a bet with him on which is more effective after the vehicle is out on the road, since he won't change it at this time. And they refused HLF and rear corner LED's. They've had issues in the past and are skittish of using them again. I tried for it and got shot down along with a full size lightbar.
Anyways, let me know what you think. Thanks!
Front Wiring Prep
Equipment added:
Front:
Cobra 400 Red/Blue
Rear:
Cobra 600 Red/Blue
Apollo F12 R/A B/A
Interior:
Icom 5021 VHF Radio
Storm Pro 200 W
Cobra 400 Red/Blue
Cobra 400 Red/Blue
Cobra 600 Red/Blue
Cobra 600 Red/Blue
D&R Center Console
