If I'm only running a single 100 watt speaker, do I need to hook up both red wires, or just one?
Z zsiya Member May 22, 2010 169 AL Jun 22, 2014 #1 If I'm only running a single 100 watt speaker, do I need to hook up both red wires, or just one?
Big D Member Feb 22, 2014 87 Croswell, MI 48422 Jun 23, 2014 #2 zsiya said: If I'm only running a single 100 watt speaker, do I need to hook up both red wires, or just one? Click to expand... If you are talking about a Whelen 295 siren, then the answer is yes, both red wires on the amplifier to the battery (30A fused) and both black wires to battery ground.
MtnMan Member Dec 20, 2012 1,533 Eastern PA Jun 23, 2014 #3 One wire, fused at 15A, would be adequate for 100W use. However, on general principle I'd connect both, in case anyone adds a second speaker later. Last edited by a moderator: Jun 23, 2014
S Skip Goulet Member Feb 23, 2011 4,241 Midland, TX Jun 26, 2014 #4 Those are just like the original SVP SA400s that Whelen built for SVP. Both reds have got to be connected.
Wailer Member May 24, 2010 2,294 Canada Jun 27, 2014 #5 Skip Goulet said: Those are just like the original SVP SA400s that Whelen built for SVP. Both reds have got to be connected. Click to expand... The old Whelen WS295s (1970s and 1980s) and the Southern VP SA400s were made by Carson. The design is based on the Carson SA300. The new Whelen WS295 series (1990s to present) are Whelen's own design. Reactions: Skip Goulet
S Skip Goulet Member Feb 23, 2011 4,241 Midland, TX Jun 27, 2014 #6 You're right....I meant to say that they were built by Carson. Another senior moment....you know! :crazy: Reactions: CodeMan
