3D Pyramid TIR Lighthead from Brooking Industries
Columbus, Ohio
Name: Pyramid TIR Lighthead
Model #: 3D
Manufacturer: Brooking Industries/Axixtech
Release Date: 2/15/13
MSRP: $55
The 3D is a 3 diode, TIR, surface mount LED. The center diode is mounted flush, while each end diode is mounted at an angle. Great for mounting on push bars, mirrors, or other places that off angle lighting is called for. The 3D comes in solid colors including Red, Blue, White and Amber.
Specifications:
  • 3.86" Length x 1.61" Width x 1.14" Height
  • 12-24 volts
  • 0.35 Amps peak current draw
  • Meets SAE J595 Class 2 & E6-10R-030265
  • Syncs with other Axixtech lightheads
We are a dealer for this product.
EMT-BLS
2,640
Waterbury, CT
Will there be an option to have the light turned into a pyramid-shaped TD? Line a whole bunch up, you'd get great scene lighting if the LED's are powerful enough.
JohnMarcson
May 7, 2010
10,971
Northwest Ohio
Attachments approved/fixed.
Waterborne
13
Detroit, MI
Do you have any video of it in action and from different angles? I channeled all of my google-fu but could not find anything, probably because it is rather new. Even pics from head-on and side angle would help.
Columbus, Ohio
They do have a steady burn flash pattern, but there's no wire to activate it as a secondary function. I don't think that was really the intent for them. You'd probably be better off buying a light that was specifically designed as a work light.
[b said:
Waterborne]Do you have any video of it in action and from different angles? I channeled all of my google-fu but could not find anything, probably because it is rather new. Even pics from head-on and side angle would help.
I will work on that this evening for you.
May 25, 2010
7,072
Tunkhannock, PA, USA
I think I like it... Angled enough to give you off axis not so much where you only have 1 LED pointing forward... :thumbsup:
GSPS629
