ERT1111
911 Circuits vehicle wiring harness model CH27 (older version)
TECHNICAL FEATURES
27 circuits (18x16gauge, 4×12 gauge, 4×10 gauge).
7 hot circuits (redx4, yellowx3).
1 Bypass circuit.
1 Siren Mute circuit (insert the siren mute resistor to this output to reduce 90% of siren volume when servicing the siren).
6 Switched outputs (orangex6).
Switched outputs can be set as either timer or ignition controlled with just the flick of switch.
12 timed outputs (whitex6, bluex6) that default to ignition controlled in case there’s no timer present.
Timer settings are easy to program with our ts1 timer.
CABLE # 1
QD 1-15
Output wire kit circuits 1 through 15 (Orange/Yellow/Red/Grey wires) 20 foot.
Weatherproof Quick Disconnect for Ch15 harness and Ch27 harness. (40 ft 10g., 40 ft 12 g. 350ft 16g)
CABLE #2
QD 16-2
Output wire kit circuits 16 through 27 (Blue and White wires) 20 foot.
Weatherproof Quick Disconnect for Ch27 harness. (80 ft 10g. 160ft 16g)
Standardized Fleet Wiring Solution
911 Circuits power distribution system was specifically engineered to address the challenges of supplying high quality and highly reliable power to emergency equipment in first responder vehicles. Due to its compact size and vehicle specific brackets, it can be installed in a variety of locations including under the hood, under the seat or on a trunk tray.
This unit is a 27-circuit complete wiring harness never installed and its untested. It is several years old and was purchased for a project that never materialized. I have misplaced all instructions but this company has very good support. I am asking $650.00 plus $25.00 shipping USA only. These cost over $1,000.00 new. It is new old stock untested and is sold as is.
TECHNICAL FEATURES
1 Bypass circuit.
CABLE # 1
QD 1-15
CABLE #2
QD 16-2
